[gdal-dev] Gdalinfo does not print into file on Windows
Rahkonen Jukka jukka.rahkonen at mmmtike.fi
Tue Sep 17 13:56:29 PDT 2013
Yes, it is the same issue. After removing the plugin "gdal_ECW_JP2ECW" the output can be directed into file. Setting GDAL_SKIP=ECW did not help.
-Jukka-
________________________________________
Even Rouault wrote:
> Hi Jukka,
> This reminds me a lot the following ticket :
> http://trac.osgeo.org/gdal/ticket/5128
> Could you confirm that the analysis done (i.e. the cause of the problem would be
> the ECW plugin) also applies to you ? I'm not sure if you must completely
> uninstall (or rename) the gdal_ECW.dll, or if specifying GDAL_SKIP=ECW as
> environmenet variable is sufficient
> Even
>> Hi,
>> I noticed that gdalinfo and gdallocationinfo tools do not print into file
>> with command
>> gdalinfo test.tif >report.txt
>> The file report.txt is created but it remains empty. With ogrinfo printing
>> into file goes well. I also had a try with some old FWTools and with that I
>> could redirect also gdalinfo report into file.
>> I was testing on Windows 7 and last nights 64-bit GDAL from trunk
>http://gisinternals.com/sdk/Download.aspx?file=release-1600-x64-gdal-mapserver.zip
>> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
