[gdal-dev] Gdalinfo does not print into file on Windows
lpinner Luke.Pinner at environment.gov.au
Tue Sep 17 16:47:22 PDT 2013
Yes, redirection and exit code setting works when the gdal_ECW_JP2ECW.dll is
built against ECW/JP2 v.5.0 SDK (didn't test v.4x).
Luke
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Gdalinfo-does-not-print-into-file-on-Windows-tp5078239p5078379.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
