[gdal-dev] assert failure (tif_open)
Frank Warmerdam
warmerdam at pobox.com
Thu Sep 26 16:54:23 PDT 2013
Nik,
I assume you are using the "built in" libtiff in GDAL. In that case the
file gdal/frmts/gtiff/libtiff/tif_config.h will include cpl_port.h and
includes this line:
#define TIFF_UINT64_T GUIntBig
I assume TIFF_UINT64 ultimately is used to define uint64.
So I think you need to go through gdal/port/cpl_port.h and
gdal/port/cpl_config.h to try and figure out how GUIntBig is getting
defined. In cpl_port.h it helps to search for the block of code titled
"64bit support". I would guess you want to use "unsigned long long" in
which case you would need to have HAVE_LONG_LONG defined in cpl_config.h.
I'm not aware of any recent changes in this logic so I'm not sure why it
used to work and doesn't now.
Best regards,
Frank
On Thu, Sep 26, 2013 at 4:33 PM, Nik Sands <nixanz at nixanz.com> wrote:
> Hi list members,
> I've been using GDAL 1.10 as a statically linked library in an iOS app for
> some time. I recently recompiled GDAL again from the same local set of
> source files, using my notes on configuration options that I used last
> time, and ever since I've been having a problem every time the app attempts
> to open an image file.
> The app fails an assert() in the included tiff library (in tif_open.c),
> throwing the error:
> Assertion failed: (sizeof(uint64)==8), function TIFFClientOpen,
> file tif_open.c, line 99.
> The line in question is the last line of the code snippet from tif_open.c
> below:
> /* The following are configuration checks. They should be
> redundant, but should not
> * compile to any actual code in an optimised release build
> anyway. If any of them
> * fail, (makefile-based or other) configuration is not correct */
> assert(sizeof(uint8)==1);
> assert(sizeof(int8)==1);
> assert(sizeof(uint16)==2);
> assert(sizeof(int16)==2);
> assert(sizeof(uint32)==4);
> assert(sizeof(int32)==4);
> assert(sizeof(uint64)==8); // <- SIBABRT HERE
> The comments indicate that there may be a problem with the "configure"
> options I used when building GDAL, however I'm using exactly the same
> options (copy and pasted) as I used last time when it worked OK.
> So this leads me to think that perhaps something has changed in my
> environment, and the only thing I can think of is that I may be using a
> different version of GCC (I'm using the 'gcc' included with Apple's 'Xcode'
> IDE, and since the last compile of GDAL, I've upgraded from a beta build of
> Xcode to the production build of Xcode 5).
> I've tried it with GDAL 1.10.1 as well and get exactly the same problem.
> I'm stumped as to how to proceed with resolving this issue. Can anybody
> help me to overcome this?
> Note that the problem occurs when running on the real iOS device (armv7s)
> and on the iOS simulator (i386).
> Cheers,
> Nik.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130926/a2219071/attachment.html>
