[gdal-dev] assert failure (tif_open)
Nik Sands nixanz at nixanz.com
Thu Sep 26 17:13:32 PDT 2013
I think you're right Frank.  It may take me some time to figure out how to get it working correctly.
Your message did remind me of one HUGE change that Apple made between the beta versions of their Xcode IDE and the final production version:  64 bit support for the new iPhone 5S.  ( https://developer.apple.com/library/ios/documentation/General/Conceptual/CocoaTouch64BitGuide/CocoaTouch64BitGuide.pdf )
So it's gotta be related to that, I reckon.  (Should have stuck with the beta version!  :-)  )
I'll post back if I can figure out the correct settings in the config files you mentioned in order to get it to work properly.
On 27/09/2013, at 9:54 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Nik,
> I assume you are using the "built in" libtiff in GDAL.  In that case the file gdal/frmts/gtiff/libtiff/tif_config.h will include cpl_port.h and includes this line:
> #define TIFF_UINT64_T GUIntBig
> I assume TIFF_UINT64 ultimately is used to define uint64.
> So I think you need to go through gdal/port/cpl_port.h and gdal/port/cpl_config.h to try and figure out how GUIntBig is getting defined.  In cpl_port.h it helps to search for the block of code titled "64bit support".  I would guess you want to use "unsigned long long" in which case you would need to have HAVE_LONG_LONG defined in cpl_config.h.
> I'm not aware of any recent changes in this logic so I'm not sure why it used to work and doesn't now.
> Best regards,
> Frank
> On Thu, Sep 26, 2013 at 4:33 PM, Nik Sands <nixanz at nixanz.com> wrote:
> Hi list members,
> I've been using GDAL 1.10 as a statically linked library in an iOS app for some time.  I recently recompiled GDAL again from the same local set of source files, using my notes on configuration options that I used last time, and ever since I've been having a problem every time the app attempts to open an image file.
> The app fails an assert() in the included tiff library (in tif_open.c), throwing the error:
>         Assertion failed: (sizeof(uint64)==8), function TIFFClientOpen, file tif_open.c, line 99.
> The line in question is the last line of the code snippet from tif_open.c below:
>         /* The following are configuration checks. They should be redundant, but should not
>          * compile to any actual code in an optimised release build anyway. If any of them
>          * fail, (makefile-based or other) configuration is not correct */
>         assert(sizeof(uint8)==1);
>         assert(sizeof(int8)==1);
>         assert(sizeof(uint16)==2);
>         assert(sizeof(int16)==2);
>         assert(sizeof(uint32)==4);
>         assert(sizeof(int32)==4);
>         assert(sizeof(uint64)==8);  //  <- SIBABRT HERE
> The comments indicate that there may be a problem with the "configure" options I used when building GDAL, however I'm using exactly the same options (copy and pasted) as I used last time when it worked OK.
> So this leads me to think that perhaps something has changed in my environment, and the only thing I can think of is that I may be using a different version of GCC (I'm using the 'gcc' included with Apple's 'Xcode' IDE, and since the last compile of GDAL, I've upgraded from a beta build of Xcode to the production build of Xcode 5).
> I've tried it with GDAL 1.10.1 as well and get exactly the same problem.
> I'm stumped as to how to proceed with resolving this issue.  Can anybody help me to overcome this?
> Note that the problem occurs when running on the real iOS device (armv7s) and on the iOS simulator (i386).
> Cheers,
> Nik.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130927/65437137/attachment.html>
