[gdal-dev] GDAL/OGR 1.11.0 Beta1 ready
David Tran david.tran at hsr.ch
Sat Apr 5 17:36:16 PDT 2014
Hi to everybody again
Hope you all enjoy gdal 1.11.0beta1.
What was the big bang between v1.9.2 and >=1.1x.y? Because my MinGW
installtion doesn't compile Gdal since version 1.10.0 at all. Only Gdal
1.9.2 with MinGW (www.mingw.org) was (configure, make, make install)
fine. I tested the binaries ogrinfo and ogr2ogr with the flag --version.
I have some compile results/errors to share:
curl-7.36.0
expat-2.1.0
proj-4.8.0 (with Datumgrid 1.6RC1)
openssl-1.0.1f
sqlite-autoconf-3080402
zlib-1.2.8
postgresql-9.3.4
== mingw32 (www.mingw.org) ==
HOST=i686-w64-mingw32
WORKSPACE=$PWD/workspace
export PATH=$WORKSPACE/bin:$WORKSPACE/lib:$PATH
./configure --prefix=$WORKSPACE --disable-static --without-grass
--without-geos --without-freexl --with-python=no --with-xerces=no
--with-jasper=no --with-mrsid=no --with-mrsid_lidar=no --with-ecw=no
--with-libz=internal --with-png=internal --with-libtiff=internal
--with-geotiff=internal --with-jpeg=internal --with-gif=internal
--with-pcraster=internal --with-threads --enable-fast-install
--with-curl --with-odbc --with-expat=$WORKSPACE
--with-static-proj4=$WORKSPACE --with-sqlite3=$WORKSPACE
--with-pg=$WORKSPACE/bin/pg_config --host=$HOST --build=$HOST
make
gdal version
1.9.2
ok.
1.10.1
make[1]: *** [cpl_xml_validate.lo] Error 1
make[1]: Leaving directory `/home/David/gdal-1.10.1/port'
make: *** [port-target] Error 2
1.11.0beta1
make[1]: Leaving directory `/home/David/gdal-1.11.0beta1/port'
svn-stable-2014.03.28
ok.
== mingw w64 rubenvb ==
make
gdal version
1.9.2
collect2.exe: error: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/home/David/gdal-1.9.2'
make: *** [check-lib] Error 2
1.10.1
make[1]: Leaving directory `/home/David/gdal-1.10.1'
1.11.0beta1
make[1]: Leaving directory `/home/David/gdal-1.11.0beta1'
Thanks again.
-------- Original Message  --------
Subject: [gdal-dev] GDAL/OGR 1.11.0 Beta1 ready
From: Even Rouault <even.rouault at mines-paris.org>
To: gdal-dev at lists.osgeo.org dev <gdal-dev at lists.osgeo.org>
Date: Friday, 4. April 2014 22:19:48
> Hi,
> I have prepared a GDAL/OGR 1.11.0 first beta release. The source
> archives can be found at :
> http://download.osgeo.org/gdal/1.11.0/gdal-1.11.0beta1.tar.gz
> http://download.osgeo.org/gdal/1.11.0/gdal-1.11.0beta1.tar.xz
> http://download.osgeo.org/gdal/1.11.0/gdal1110beta1.zip
> The NEWS for the release can be found at the top of:
> http://svn.osgeo.org/gdal/trunk/gdal/NEWS
> As usual, you are warmly invited to test and report (ideally with
> patches) anything that must be fixed before the release :
> http://trac.osgeo.org/gdal/
> There will be perhaps another beta, but if things go smoothly, the
> next step will be RC1 (let's say end of next week).
> Note: due to the current unavailability of gdal.org, which is the
> machine on which releases are usually prepared, I've created the
> snapshot on my PC. Hopefully this will have no consequence on the
> above archives.
> Best regards,
> Even
