[gdal-dev] GDAL/OGR 1.11.0 Beta1 ready
Volker Fröhlich
volker27 at gmx.at
Sun Apr 6 12:19:37 PDT 2014
Am 2014-04-06 20:16, schrieb Even Rouault:
> Hi Volker,
>> Hi!
>> Is "walk" compiled as soon as you enable odbc?
> Yes
>> I'm getting the following
>> compiler error on EL6:
> Hum, from the error location, I suppose this is a big-endian host ? r27136
> should fix it.
> Even
Oh, right, I should have mentioned that! The patch resolves the issue.
Thanks!
Volker
