[gdal-dev] GDAL/OGR 1.11.0 Beta1 ready
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Sun Apr 6 12:22:22 PDT 2014
Hei Even,
Thanks for the beta release. I tested with special focus on GRASS 7, because in the news it says that:
"GRASS driver:
 * fix compilation issues for GRASS 7"
I can confirm, that GDAL can be built against GRASS 7.
gdalinfo --formats gives:
GRASS (ro): GRASS Database Rasters (5.7+)
However, the GRASS driver does not work with GRASS 7 rasters (at least not for me on UBUNTU 12.04 LTS).
When I call gdalinfo on a GRASS 7 raster I get:
Segmentation fault (core dumped)
Seems like ticket #2953 (http://trac.osgeo.org/gdal/ticket/2953) is still valid.
Cheers
Stefan
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Even Rouault
Sent: 4. april 2014 22:20
To: gdal-dev at lists.osgeo.org dev
Subject: [gdal-dev] GDAL/OGR 1.11.0 Beta1 ready
I have prepared a GDAL/OGR 1.11.0 first beta release. The source archives can be found at :
  http://download.osgeo.org/gdal/1.11.0/gdal-1.11.0beta1.tar.gz
  http://download.osgeo.org/gdal/1.11.0/gdal-1.11.0beta1.tar.xz
  http://download.osgeo.org/gdal/1.11.0/gdal1110beta1.zip
The NEWS for the release can be found at the top of:
  http://svn.osgeo.org/gdal/trunk/gdal/NEWS
As usual, you are warmly invited to test and report (ideally with patches) anything that must be fixed before the release : http://trac.osgeo.org/gdal/
There will be perhaps another beta, but if things go smoothly, the next step will be RC1 (let's say end of next week).
Note: due to the current unavailability of gdal.org, which is the machine on which releases are usually prepared, I've created the snapshot on my PC.
Hopefully this will have no consequence on the above archives.
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
