[gdal-dev] gdal_rasterize
Chaitanya kumar CH
chaitanya.ch at gmail.com
Tue Apr 8 22:08:19 PDT 2014
Jason,
Can you provide some sample data to reproduce the error?
On Wed, Apr 9, 2014 at 3:51 AM, Jason Mathis <jmathis at redzonesoftware.com>wrote:
> Hi all was wondering if anyone could help out here. I have been trying to
> rasterize a shp file using gdal_rasterize and I keep getting an error I
> have no idea about.
> gdal_rasterize(1844,0x7fff7a393310) malloc: *** error for object
> 0x7f8f40d032e0: pointer being freed was not allocated
> *** set a breakpoint in malloc_error_break to debug
> the command I am using is:
> gdal_rasterize -at -burn 1 -a $attribute -where “$attribute=‘value'" -ts
> 5000 5000 $shapefile $outfile
> version is:
> GDAL 1.10.0, released 2013/04/24
> I am running os x 10.9.2.
> It seems to happen randomly. I have about 10 different values I need to
> get out. Not sure what other info would be useful so please let me know.
> thanks!
> -jason
> This transmission contains confidential and privileged information
> intended solely for the party identified above. If you receive this message
> in error, you must not use it or convey it to others. Please destroy it
> immediately and contact the sender at (303) 386-3955 or by return e-mail to
> the sender.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140409/c032e35a/attachment-0001.html>
