[gdal-dev] gdal_rasterize
Jason Mathis jmathis at redzonesoftware.com
Wed Apr 9 07:43:58 PDT 2014
That maybe difficult, not sure I can share the shapefile I am using. Although I could try and find a sample and reproduce the error; if I can.
Are you thinking this could be data related?
I will respond when i can reproduce.
Thanks!
On April 8, 2014 at 11:08:20 PM, Chaitanya kumar CH (chaitanya.ch at gmail.com) wrote:
Jason,
Can you provide some sample data to reproduce the error?
On Wed, Apr 9, 2014 at 3:51 AM, Jason Mathis <jmathis at redzonesoftware.com> wrote:
Hi all was wondering if anyone could help out here. I have been trying to rasterize a shp file using gdal_rasterize and I keep getting an error I have no idea about.
gdal_rasterize(1844,0x7fff7a393310) malloc: *** error for object 0x7f8f40d032e0: pointer being freed was not allocated
*** set a breakpoint in malloc_error_break to debug
the command I am using is:
gdal_rasterize -at -burn 1 -a $attribute -where “$attribute=‘value'" -ts 5000 5000 $shapefile $outfile
version is:
GDAL 1.10.0, released 2013/04/24
I am running os x 10.9.2.
It seems to happen randomly. I have about 10 different values I need to get out. Not sure what other info would be useful so please let me know.
thanks!
-jason
This transmission contains confidential and privileged information intended solely for the party identified above. If you receive this message in error, you must not use it or convey it to others. Please destroy it immediately and contact the sender at (303) 386-3955 or by return e-mail to the sender.
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
the sender.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140409/006bb1d7/attachment.html>
