[gdal-dev] Import .GDB into MSSQL Server database
Jan Heckman
jan.heckman at gmail.com
Wed Apr 9 01:13:05 PDT 2014
Hey Kyle,
I had missed it can now read earlier gdb! Great!
Thanks for the head(s)-up!!
Jan
On Wed, Apr 9, 2014 at 12:52 AM, Kyle Shannon <kyle at pobox.com> wrote:
> On Tue, Apr 8, 2014 at 4:47 PM, Jan Heckman <jan.heckman at gmail.com> wrote:
> > Depends on the geodatabase version.
> > If (AG) 10, there is a ogr driver for it, so you would not need
> shapefiles
> > and avoid losing long fieldnames etc.
> > There is no driver for earlier AG/gdb versions.
> OpenFileGDB should handle earlier versions, read only:
> http://gdal.org/ogr/drv_openfilegdb.html
> It's in the trunk.
> > Maybe it's an old thread, but it has some information.
> > Integration in ogr.
> > good luck,
> > Jan
> > On Tue, Apr 8, 2014 at 8:44 PM, cdp <cdaponte at synergyaspen.ca> wrote:
> >> Any ideas on how to import a .GDB into MSSQL Server database without
> >> converting to a .shp first?
> >> Thanks all!
> >> C
> >> View this message in context:
> http://osgeo-org.1560.x6.nabble.com/Import-GDB-into-MSSQL-Server-database-tp5133917.html
> >> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Kyle
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140409/8d1b2d38/attachment.html>
