[gdal-dev] [EXTERNAL] oci and oracle express 11
Ivan Lucena lucena_ivan at hotmail.com
Fri Apr 11 09:11:29 PDT 2014
I glad to know that it solved your problem, even with my poor cellphone typing. It seems like Windows doesn't detect that the oci.dll version/architecture is wrong and loads it with without a problem, but  when the GDAL driver try to call the OCI API to open a connection that error comes as a default. What is very misleading. It has nothing to deal with SID or the Listener setting.
> Date: Fri, 11 Apr 2014 12:08:35 +0200
> Subject: Re: [gdal-dev] [EXTERNAL] oci and oracle express 11
> From: landa.martin at gmail.com
> To: lucena_ivan at hotmail.com
> CC: mateusz at loskot.net; gdal-dev at lists.osgeo.org; michael.smith at erdc.dren.mil
> Hi all,
> 2014-04-11 4:00 GMT+02:00 Ivan Lucena <lucena_ivan at hotmail.com>:
> > I know that is not the same situation you have, but when I need to run GDAL
> > build for Win32 on my Win64 machine I need to place an OCI.DLL from a
> > InstantClient-32 first on my PATH. Otherwise it will try to load the default
> > on DLL my system, that happens to a Win64 OCI.DLL.
> that was! When I removed oci.dll from c:\osgeo4w than it started magically work!
> ogrinfo -ro OCI:user/passwd
> Thanks for saving me from madness :-) Martin
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140411/6a644e05/attachment.html>
