[gdal-dev] Problems with large ASTER GeoTIFF
MORREALE Jean Roc
jr.morreale at enoreth.net
Tue Apr 15 10:43:49 PDT 2014
If you're talking about the EAA EU_DEM then PNG isn't a good solution as
the whole raster as to be loaded to access a subset of it, a compressed
TIFF with TILED=YES would be better.
Also, you should not try to scale it down to byte as it would only 255
values, if I remember well the original data is in ctfloat32 so try to
scale it down to int32 for a huge size gain.
Le 15/04/2014 16:51, Nicole Stoffels a écrit :
> Thanks Chaitanya!
>> The problem is reading the source file itself. GDAL is unable to find
>> any valid pixels. Check if you are using the latest GDAL binaries. Use
>> "gdalinfo -version".
> I just installed the latest gdal-version (1.10.1). But it did not solve
> my problems. I still get the same error while trying to display the min
> and max.
> Use qgis to view the input and output. GIMP can't
>> handle anything except basic pixel types.
> But with qgis I can visualize my original large EU_DEM-files. :)
> Best regards
> Nicole
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
