[gdal-dev] Problems with large ASTER GeoTIFF
Chaitanya kumar CH
chaitanya.ch at gmail.com
Tue Apr 15 09:46:16 PDT 2014
Nicole,
You should be able to perform those operations from qgis too. Crop it to
your extents, scale the pixel values and save as PNG.
Best regards,
Chaitanya Kumar CH
On 15-Apr-2014 8:21 pm, "Nicole Stoffels" <stoffels at f2e.de> wrote:
> Thanks Chaitanya!
>> The problem is reading the source file itself. GDAL is unable to find
>> any valid pixels. Check if you are using the latest GDAL binaries. Use
>> "gdalinfo -version".
> I just installed the latest gdal-version (1.10.1). But it did not solve my
> problems. I still get the same error while trying to display the min and
> max.
> Use qgis to view the input and output. GIMP can't
>> handle anything except basic pixel types.
> But with qgis I can visualize my original large EU_DEM-files. :)
> Best regards
> Nicole
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140415/abec2665/attachment.html>
