[gdal-dev] problem with gdal_translate jp2 file from the usgs (linux)
Kasper van Wijk k.vanwijk at auckland.ac.nz
Thu Apr 24 17:25:00 PDT 2014
Eli: thanks for the new repo. This got me from gdal 1.7.3 to 1.9.1, but
still the same warning/output
Trent: I downloaded the linux binaries and followed the instructions in the
README (about PATHS), but:
kasper at PALette:~/Downloads$ kdu_expand -i
m_3810623_ne_13_1_20110921_20111031.jp2 -o geo.tif -num_threads 2
bash: /home/kasper/kakadu/bin/kdu_expand: cannot execute binary file
Even: I managed to install the http://gdal.org/frmt_jp2openjpeg.html, and
downloaded and install gdal1.10 against the openjpeg libs, but
kasper at PALette:~/Downloads/gdal-1.10.1$ !gdal
gdal_translate
ERROR 1: gdal_translate was compiled against GDAL 1.10 but current library
version is 1.9
How/where do I get the 1.10 libs? Or should I install GDAL1.09 to match?
Cheers,
kasper
On 25 April 2014 09:43, Eli Adam <eadam at co.lincoln.or.us> wrote:
> Kasper,
> On Thu, Apr 24, 2014 at 2:32 PM, Even Rouault
> <even.rouault at mines-paris.org> wrote:
> > Le jeudi 24 avril 2014 23:29:03, Kasper van Wijk a écrit :
> >> thank you, Even, for the fast reply. I am a beginner at GDAL and
> installed
> >> the gdal suite with "standard" apt-get and yum, respectively. Can you
> point
> >> me to a place where I can read how to compile GDAL against one of the
> other
> >> JPEG2000 libraries, as you say?
> Compiling is a great option and might be the best.  You might also
> want to check which drivers are in Ubuntu GIS and Enterprise Linux GIS
> which might be easier than compiling.  They are often more recent and
> with more features than the standard repos.
> https://wiki.ubuntu.com/UbuntuGIS
> http://wiki.osgeo.org/wiki/Enterprise_Linux_GIS
> Best regards, Eli
> > You will find various resources at
> http://trac.osgeo.org/gdal/wiki/BuildHints
> > Most interesting links for your use case :
> > * http://trac.osgeo.org/gdal/wiki/DownloadSource
> > * http://trac.osgeo.org/gdal/wiki/BuildingOnUnix
> > * http://trac.osgeo.org/gdal/wiki/ECW : if you want to compile against
> ECW SDK
> > * http://gdal.org/frmt_jp2openjpeg.html : if you want to compile against
> > OpenJPEG v2
> >> Thanks again,
> >> Kasper
> >> On 25 April 2014 09:25, Even Rouault <even.rouault at mines-paris.org>
> wrote:
> >> > Le jeudi 24 avril 2014 23:17:29, Kasper van Wijk a écrit :
> >> > > dear all,
> >> > > I am downloading jp2 data from the usgs national map. To plot this
> in
> >> > > cartopy, I need to transform to something else, such as geotiff.
> >> > > However, using gdal_translate I get a warning copied below, and the
> >> > > output is a grainy bw version of the image. I have checked my
> results
> >> > > under linux
> >> > both
> >> > > fedora core 20 and ubuntu 12.04 versions with GDAL 1.7.3, released
> >> > > 2010/11/10
> >> > > gdal_translate m_3810623_ne_13_1_20110921_20111031.jp2 test.tiff -of
> >> > GTiff
> >> > > warning: not enough tile data (2 bytes)
> >> > Apparently your GDAL build uses libjasper as the jpeg2000 library.
> Jasper
> >> > doesn't work very well unfortunately with some real world images.
> >> > You might want to compile GDAL against one of the other JPEG2000
> >> > libraries that are supported : see http://gdal.org/formats_list.html
> >> > Geospatial professional services
> >> > http://even.rouault.free.fr/services.html
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140425/7e7353d1/attachment.html>
