[gdal-dev] problem with gdal_translate jp2 file from the usgs (linux)
Simon Shak skunkmyrddyn at gmail.com
Thu Apr 24 17:29:28 PDT 2014
Personally I recommend either the erdas ecwj2k or mrsid driver for uses jp2
files.
On Apr 24, 2014 7:25 PM, "Kasper van Wijk" <k.vanwijk at auckland.ac.nz> wrote:
> Eli: thanks for the new repo. This got me from gdal 1.7.3 to 1.9.1, but
> still the same warning/output
> Trent: I downloaded the linux binaries and followed the instructions in
> the README (about PATHS), but:
> kasper at PALette:~/Downloads$ kdu_expand -i
> m_3810623_ne_13_1_20110921_20111031.jp2 -o geo.tif -num_threads 2
> bash: /home/kasper/kakadu/bin/kdu_expand: cannot execute binary file
> Even: I managed to install the http://gdal.org/frmt_jp2openjpeg.html, and
> downloaded and install gdal1.10 against the openjpeg libs, but
> kasper at PALette:~/Downloads/gdal-1.10.1$ !gdal
> gdal_translate
> ERROR 1: gdal_translate was compiled against GDAL 1.10 but current library
> version is 1.9
> How/where do I get the 1.10 libs? Or should I install GDAL1.09 to match?
> Cheers,
> kasper
> On 25 April 2014 09:43, Eli Adam <eadam at co.lincoln.or.us> wrote:
>> Kasper,
>> On Thu, Apr 24, 2014 at 2:32 PM, Even Rouault
>> <even.rouault at mines-paris.org> wrote:
>> > Le jeudi 24 avril 2014 23:29:03, Kasper van Wijk a écrit :
>> >> thank you, Even, for the fast reply. I am a beginner at GDAL and
>> installed
>> >> the gdal suite with "standard" apt-get and yum, respectively. Can you
>> point
>> >> me to a place where I can read how to compile GDAL against one of the
>> other
>> >> JPEG2000 libraries, as you say?
>> Compiling is a great option and might be the best.  You might also
>> want to check which drivers are in Ubuntu GIS and Enterprise Linux GIS
>> which might be easier than compiling.  They are often more recent and
>> with more features than the standard repos.
>> https://wiki.ubuntu.com/UbuntuGIS
>> http://wiki.osgeo.org/wiki/Enterprise_Linux_GIS
>> Best regards, Eli
>> > You will find various resources at
>> http://trac.osgeo.org/gdal/wiki/BuildHints
>> > Most interesting links for your use case :
>> > * http://trac.osgeo.org/gdal/wiki/DownloadSource
>> > * http://trac.osgeo.org/gdal/wiki/BuildingOnUnix
>> > * http://trac.osgeo.org/gdal/wiki/ECW : if you want to compile against
>> ECW SDK
>> > * http://gdal.org/frmt_jp2openjpeg.html : if you want to compile
>> against
>> > OpenJPEG v2
>> >> Thanks again,
>> >> Kasper
>> >> On 25 April 2014 09:25, Even Rouault <even.rouault at mines-paris.org>
>> wrote:
>> >> > Le jeudi 24 avril 2014 23:17:29, Kasper van Wijk a écrit :
>> >> > > dear all,
>> >> > > I am downloading jp2 data from the usgs national map. To plot this
>> in
>> >> > > cartopy, I need to transform to something else, such as geotiff.
>> >> > > However, using gdal_translate I get a warning copied below, and the
>> >> > > output is a grainy bw version of the image. I have checked my
>> results
>> >> > > under linux
>> >> > both
>> >> > > fedora core 20 and ubuntu 12.04 versions with GDAL 1.7.3, released
>> >> > > 2010/11/10
>> >> > > gdal_translate m_3810623_ne_13_1_20110921_20111031.jp2 test.tiff
>> -of
>> >> > GTiff
>> >> > > warning: not enough tile data (2 bytes)
>> >> > Apparently your GDAL build uses libjasper as the jpeg2000 library.
>> Jasper
>> >> > doesn't work very well unfortunately with some real world images.
>> >> > You might want to compile GDAL against one of the other JPEG2000
>> >> > libraries that are supported : see http://gdal.org/formats_list.html
>> >> > Geospatial professional services
>> >> > http://even.rouault.free.fr/services.html
>> > _______________________________________________
>> > gdal-dev mailing list
>> > gdal-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140424/e4968729/attachment-0001.html>
