[gdal-dev] debug ogr2ogr on Windows
Even Rouault
even.rouault at mines-paris.org
Fri Apr 25 10:34:32 PDT 2014
Le vendredi 25 avril 2014 19:31:08, Martin Landa a écrit :
> Hi Ivan,
> 2014-04-24 23:27 GMT+02:00 Ivan Lucena <lucena_ivan at hotmail.com>:
> first of all, thanks a lot for very useful notes!
> > Press F7 will build everything but you don't need to do that if you have
> > done in command line.
> I tried to build GDAL also from VC, but it ends with
> 1> lib /nologo /out:gdal.lib port\*.obj gcore\*.obj alg\*.obj
> frmts\o\*.obj ogr\ogrsf_frmts\ogrsf_frmts.lib ogr\ogr.lib
> 1>nitf_gcprpc.obj : warning LNK4221: This object file does not define
> any previously undefined public symbols, so it will not be used by any
> link operation that consumes this library
> 1> link /nologo /dll /INCLUDE:_OGRFeatureStylePuller
> /INCLUDE:_OSRValidate /INCLUDE:_OPTGetProjectionMethods
> /INCLUDE:_OGR_G_GetPointCount /INCLUDE:_OGRRegisterAll
> /INCLUDE:_GDALSimpleImageWarp at 36 /INCLUDE:_GDALReprojectImage at 48
> /INCLUDE:_GDALComputeMedianCutPCT at 32 /INCLUDE:_GDALDitherRGB2PCT at 28
> /INCLUDE:_OCTNewCoordinateTransformation at 8 port\*.obj gcore\*.obj
> alg\*.obj frmts\o\*.obj ogr\ogrsf_frmts\ogrsf_frmts.lib ogr\ogr.lib
> C:\oraclexe\app\oracle\product\11.2.0\server\oci\lib\msvc\ociw32.lib
> C:\oraclexe\app\oracle\product\11.2.0\server\oci\lib\msvc\oci.lib
> odbc32.lib odbccp32.lib user32.lib
> ws2_32.lib gcore\Version.res /out:gdal111.dll
> /implib:gdal_i.lib /debug
> 1> Creating library gdal_i.lib and object gdal_i.exp
> 1>cpl_http.obj : error LNK2019: unresolved external symbol
> __imp__curl_easy_setopt referenced in function "void __cdecl
> CPLHTTPSetOptions(void *,char * *)"
> (?CPLHTTPSetOptions@@YAXPAXPAPAD at Z)
> 1>cpl_vsil_curl.obj : error LNK2001: unresolved external symbol
> 1>cpl_vsil_curl_streaming.obj : error LNK2001: unresolved external
> symbol __imp__curl_easy_setopt
> Any idea what could be wrong?
Looks like you have defined CURL_INC, but not CURL_LIB in your nmake.local /
nmake.opt
> > 5. Prepare a command line on Project/Properties/debug
> > I can give more info tomorrow. I can't remember how the UI goes but is
> > very simple.
> Thanks in advance for very valuable help! Martin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
