[gdal-dev] debug ogr2ogr on Windows
Martin Landa landa.martin at gmail.com
Fri Apr 25 10:48:23 PDT 2014
2014-04-25 19:34 GMT+02:00 Even Rouault <even.rouault at mines-paris.org>:
> Looks like you have defined CURL_INC, but not CURL_LIB in your nmake.local /
> nmake.opt
you are right, I double-checked nmake32.opt which is used to build
GDAL from cmd line and found the problem. Sorry for the noise. Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
