[gdal-dev] MapInfo File vs ESRI Shapefile attribute value encoding
Max Demars
burton449geo at gmail.com
Tue Apr 29 12:32:11 PDT 2014
I am a bit confused right now about a possible difference in encoding
attribute value that I have noticed between those two drivers (MapInfo File
vs ESRI Shapefile).
I have a script that allow user to export some features from database to
shapefile or MapInfo TAB format. However, in MapInfo TAB the attributes are
not encoded correctly in utf-8, contrary than shapefiles.
The same data and the same code is used, and I am starting to think that
the difference is coming from inside the OGR drivers.
OGRFeature.SetField("FiedlName", value.encode('utf-8')) #value is unicode
Anybody have information about this issue? I dont really know where to look.
-Max Demars
Stack Overflow: http://stackoverflow.com/users/1914034/burton449
GIS Overflow: http://gis.stackexchange.com/users/14426/burton449
LastFm: http://www.lastfm.fr/user/burton449
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140429/e393886b/attachment.html>
