[gdal-dev] postgis to esri shape slow
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Wed Apr 30 05:59:18 PDT 2014
Mario Jurcevic <mario <at> geosar.ch> writes:
> Postgresql 9.1.3
> Postgis 2.0.4
> gdal 1.9.2
> Tables have MULTIPOLYGONS and MULTILINESTRING.
> The export is done from Java by invoking for each table the ogr2ogr
> command. Same for "pgsqltoshape".
Could you try also by running the same ogr2ogr command from command line,
possibly with --debug ON ? And tell us some summary info about the layer
captured with ogrinfo -so.
-Jukka Rahkonen-
