[gdal-dev] feature.clone() -> same featuredefn
Even Rouault
even.rouault at mines-paris.org
Mon Aug 4 04:56:55 PDT 2014
Le lundi 04 août 2014 12:46:22, Martin Landa a écrit :
> Hi Even,
> 2014-08-02 22:18 GMT+02:00 Even Rouault <even.rouault at mines-paris.org>:
> > You can use the SetFrom() method.
> it solved my problem, but it doesn't seems to copy geometry columns...
> ofeature = ogr.Feature(olayer.GetLayerDefn())
> ofeature.SetFrom(feature)
> print feature.GetDefnRef().GetGeomFieldCount(),
> feature.GetDefnRef().GetFieldCount()
> print ofeature.GetDefnRef().GetGeomFieldCount(),
> ofeature.GetDefnRef().GetFieldCount()
> 2 31
> 0 31 <-- 0!!!
Perhaps check that the line
olayer.CreateGeomField(feat_defn.GetGeomFieldDefn(i)) is executed and its
return code is 0.
Also, when running CreateLayer() with geom_type != wkbNone, this will create a
default geometry field, which might get recreated again in your geometry field
creation loop. But it does not look like like it is the case in your
situation.
> Martin
Geospatial professional services
http://even.rouault.free.fr/services.html
