[gdal-dev] GSoC 2014 Weekly Report 11 : GDAL PostGIS Raster driver
Varun Saraf
varunsaraf14 at gmail.com
Mon Aug 4 12:38:36 PDT 2014
Hello,
Yes, the code on the github repository is the latest state. I was trying
the following input queries :
(1) Assuming that my Create() will be called.
gdal_translate --debug ON -of PostGISRaster ~/GSoC/ap_clip5x5.tif
PG:"host=localhost port=5432 user=postgres password=postgres
dbname=test123 table=newtable"
(2) When that did not work, I tried the following (suggested by my mentor,
Jorge Arevalo) which didn't work either.
gdal_translate --debug ON -of PostGISRaster -outsize 50% 50%
~/GSoC/ap_clip5x5.tif PG:"host=localhost port=5432 user=postgres
password=postgres dbname=test123 table=newtable"
QuiteDelete() method is called in both cases and the following error
messages are shown
ERROR 1: Couldn't drop the table public.newtable: ERROR: table "newtable"
does not exist
ERROR 6: PostGISRasterDataset::CreateCopy() only works on source datasets
that are PostGISRaster
I even tried calling the Create() method directly from CreateCopy(), since
that is being called, but again the same error message is being printed.
Regards,
Varun Saraf
On Mon, Aug 4, 2014 at 11:33 PM, Even Rouault <even.rouault at mines-paris.org>
wrote:
> Le lundi 04 août 2014 14:39:52, Varun Saraf a écrit :
> > Hi,
> > Below is my eleventh weekly report.
> > *What did I do this week?*
> > - There are some issues with the calling of different methods. My
> method
> > PostGISRasterDataset::Create() is not being called. Tried to resolve
> > that.
> Varun,
> If the code at
> https://github.com/varunsaraf/postgis_raster/blob/master/postgisrasterdataset.cpp
> is the latest state, I don't see any reason why your Create() method
> wouldn't
> be called. Do you try to trigger it directly by calling Create()
> explicetely
> or through other more high level operations ?
> Even
> > - Fixed some small bugs and removed unnecessary variables that were
> > being used.
> > *What do I plan on doing next week?*
> > - Continue with testing and bug fixing.
> > *Am I blocked on anything?*
> > - No.
> > Link to weekly report :
> > https://github.com/varunsaraf/postgis_raster/wiki/Report-11
> > Link to code repository : https://github.com/varunsaraf/postgis_raster
> > More details at : http://trac.osgeo.org/gdal/wiki/PostGIS_raster_driver
> > Regards,
> > Varun Saraf
> > Lab for Spatial Informatics
> > IIIT Hyderabad, India
> Geospatial professional services
> http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140805/c709dc0a/attachment.html>
