[gdal-dev] AVHRR level 1b Earth Location data Interpolation
Morteza Ghavami
smor.prg at gmail.com
Fri Aug 8 02:10:29 PDT 2014
Hi ,
GDAL level1b dataset reader interpolate earth location data by lagrange
interpolation but it is not accurate .
mpop (http://www.github.com/mraspaud/mpop) interpolation method accuracy is
better than GDAL interpolation method but it uses all data records location
data . Charles Wivell suggest to use satellite/sensor/earth model . I can't
found good resources that describe this model .
Note : I found a satellite/sensor/earth model interpolation that
implemented in AAPP package but it's accuracy is similar to lagrange
method's accuracy .
Is there any interpolation method that works on only one data record and
produce accurate results ?
Thanks
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140808/0102aca7/attachment.html>
