[gdal-dev] GDAL - GDB issue
Scott Rowles scott_rowles at hotmail.com
Thu Aug 14 10:20:33 PDT 2014
I have an implementation with C# using GDAL 1.11 binaries.  According to the documentation it should process GDB files either as a .zip file, as a .gdb folder or as a .gdbtalbe individually.
I have tried all 3 of them and each one gives me an ogc.Open, cannot open this file type error.
Is there a switch I need to set or anything I need to do in the GDAL configuration to enable GDB conversion?
scott
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140814/01cb6c3a/attachment-0001.html>
