[gdal-dev] GDAL - GDB issue
Even Rouault
even.rouault at spatialys.com
Thu Aug 14 10:25:40 PDT 2014
Selon Scott Rowles <scott_rowles at hotmail.com>:
> Hi,
> I have an implementation with C# using GDAL 1.11 binaries. According to the
> documentation it should process GDB files either as a .zip file, as a .gdb
> folder or as a .gdbtalbe individually.
> I have tried all 3 of them and each one gives me an ogc.Open, cannot open
> this file type error.
> Is there a switch I need to set or anything I need to do in the GDAL
> configuration to enable GDB conversion?
Well, it should work. Did you try with the ogrinfo utility to see if the dataset
is recognized ?
Even
http://www.spatialys.com
