[gdal-dev] GDAL - GDB issue
Scott Rowles scott_rowles at hotmail.com
Thu Aug 14 10:41:48 PDT 2014
Even,
No.  Where do I find/download the ogrInfo utility.  I will try that!
scott
> Date: Thu, 14 Aug 2014 19:25:40 +0200
> From: even.rouault at spatialys.com
> To: scott_rowles at hotmail.com
> CC: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] GDAL - GDB issue
> Selon Scott Rowles <scott_rowles at hotmail.com>:
> > Hi,
> > I have an implementation with C# using GDAL 1.11 binaries.  According to the
> > documentation it should process GDB files either as a .zip file, as a .gdb
> > folder or as a .gdbtalbe individually.
> > I have tried all 3 of them and each one gives me an ogc.Open, cannot open
> > this file type error.
> > Is there a switch I need to set or anything I need to do in the GDAL
> > configuration to enable GDB conversion?
> Well, it should work. Did you try with the ogrinfo utility to see if the dataset
> is recognized ?
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140814/0c7b0699/attachment.html>
