[gdal-dev] GDAL - GDB issue
Even Rouault even.rouault at spatialys.com
Thu Aug 14 10:45:09 PDT 2014
Selon Scott Rowles <scott_rowles at hotmail.com>:
> Even,
> No.  Where do I find/download the ogrInfo utility.  I will try that!
It should be included in every binary distribution of gdal (e.g.
http://gisinternals.com/sdk/). Or if you compile it from source. It is one of
the many utilities coming with the GDAL library.
> scott
> > Date: Thu, 14 Aug 2014 19:25:40 +0200
> > From: even.rouault at spatialys.com
> > To: scott_rowles at hotmail.com
> > CC: gdal-dev at lists.osgeo.org
> > Subject: Re: [gdal-dev] GDAL - GDB issue
> > > Hi,
> > > I have an implementation with C# using GDAL 1.11 binaries.  According to
> the
> > > documentation it should process GDB files either as a .zip file, as a
> .gdb
> > > folder or as a .gdbtalbe individually.
> > > I have tried all 3 of them and each one gives me an ogc.Open, cannot open
> > > this file type error.
> > > Is there a switch I need to set or anything I need to do in the GDAL
> > > configuration to enable GDB conversion?
> > Well, it should work. Did you try with the ogrinfo utility to see if the
> dataset
> > is recognized ?
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
