[gdal-dev] RFC 47 and Threading
Even Rouault even.rouault at spatialys.com
Wed Aug 20 13:26:35 PDT 2014
I guess the silence in thread is due to people being impressed by the
austerity of the topic...
For what is worth, I've had a few opportunities to discuss directly with Blake
about his work. I'm very impressed with his energy and enthousiasm to hack in
that difficult core area of GDAL, and his understanding of the current code base
! But I must confess I'm concerned by the amount of changes and the difficulty
to ensure their correctness. Especially with three different mutexes...
I'm not sure the ratio gain/effort to make dataset methods "a bit more" thread
safe is high enough. Very few drivers can be made fully thread-safe, and fully
parallelized (i.e. without a big mutex). Basically all file-based drivers or
database-based drivers cannot. The former ones because the file handle cannot
be used simultaneously by different threads. The latter ones for the same
reason with the database connection handles. So basically that would just
address the case of the MEM driver (which is an important use case for Blake).
And in that instance, it would already be possible to use several MEM dataset
handles that would point to the same memory buffer (and with a tiny per-dataset
cache size since it is not really needed for a fast datasource such as MEM)
On the other side, I would be very pleased with having "just" the preliminary
step of Blake's work, i.e. the possibility to choose a per-band block cache
strategy instead of the global block cache. That should already address most
scaling issues.
Even
> I wanted to call to everyone's attention the work I have been doing in an
> attempt to make it possible for more portions of GDAL to be thread safe and
> improve speed in multi-threaded environments. I have put a RFC up here:
> http://trac.osgeo.org/gdal/wiki/rfc47_dataset_caching
> Originally my work focused on simply changing the way the LRU cache
> operated, but I ended up doing more in an attempt to make it much more
> efficient while still being thread safe.
> Being that this is a core part of GDAL, I wanted to get everyone's
> thoughts/questions/concerns on the different ways I have gone about
> attempting to solve this problem.
> Thanks,
> Blake
http://www.spatialys.com
