[gdal-dev] SVG support
Scott Rowles
scott_rowles at hotmail.com
Fri Aug 29 08:45:50 PDT 2014
Yep. I don't know the origin of the SVG file. I am going to try an SVG file from the Cloudmade site and verify that it works!
Date: Fri, 29 Aug 2014 09:44:43 -0600
To: scott_rowles at hotmail.com; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] SVG support
What is the source of your SVG file?
According to the SVG
driver page, only files produced with the Cloudmade Vector
Stream Server will work.
On 8/29/2014 9:25 AM, Scott Rowles wrote:
I am using the 1.11 precompiled binaries with with libexpat
included in the GDAL_DATA path. I am trying to read an SVG
file, which according to the vector format support table
should work. But it is failing and saying that it cannot open
the file.
Any thoughts on how to troubleshoot/resolve this?
scott
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140829/a07a16e0/attachment.html>
