[gdal-dev] SVG support
Scott Rowles scott_rowles at hotmail.com
Fri Aug 29 08:58:52 PDT 2014
Does cloudmade have any import and export tools that I could load in a CSV or shapefile and get a valid SVG returned?
To: gdal at stripfamily.net; gdal-dev at lists.osgeo.org
Date: Fri, 29 Aug 2014 11:45:50 -0400
Subject: Re: [gdal-dev] SVG support
Yep.  I don't know the origin of the SVG file.  I am going to try an SVG file from the Cloudmade site and verify that it works!
Date: Fri, 29 Aug 2014 09:44:43 -0600
To: scott_rowles at hotmail.com; gdal-dev at lists.osgeo.org
    What is the source of your SVG file?
    According to the SVG
      driver page, only files produced with the Cloudmade Vector
    Stream Server will work.
    On 8/29/2014 9:25 AM, Scott Rowles wrote:
        I am using the 1.11 precompiled binaries with with libexpat
          included in the GDAL_DATA path.  I am trying to read an SVG
          file, which according to the vector format support table
          should work.  But it is failing and saying that it cannot open
          the file.
        Any thoughts on how to troubleshoot/resolve this?
        scott
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140829/9e461aec/attachment.html>
