[gdal-dev] Problem encountered in stitching/merging the raster files
user_name ljvillarin30 at gmail.com
Sun Aug 31 21:03:50 PDT 2014
I tried adding -dstnodata 0 to gdalwarp(I just add one 0 because it has
only 1 band.Am I doing the right thing?) I have attached here the output.
It really didn't stitch/mosaic well. The output is still the same. I'm
really confused?
On Sat, Aug 30, 2014 at 12:31 AM, Rahkonen Jukka (Tike) [via OSGeo.org] <
ml-node+s1560n5159142h49 at n6.nabble.com> wrote:
> user_name <ljvillarin30 <at> gmail.com> writes:
> > I've tried your suggestion but then the result was this:
> > Note: I used OpenEV to open the file.
> > <http://osgeo-org.1560.x6.nabble.com/file/n5158992/openev.gif>
> Hi,
> Result looks like it is because the black slivers which are created by
> warping are not made transparent. Have a try by adding -dstnodata 0 0 0 to
> the gdalwarp command.
> -Jukka Rahkonen-
> gdal-dev mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5159142&i=0>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Problem-encountered-in-stitching-merging-the-raster-files-tp5158957p5159142.html
>  To unsubscribe from Problem encountered in stitching/merging the raster
> files, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5158957&code=bGp2aWxsYXJpbjMwQGdtYWlsLmNvbXw1MTU4OTU3fC03MDA3NDA3OTM=>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
transparent.tif (77K) <http://osgeo-org.1560.x6.nabble.com/attachment/5159338/0/transparent.tif>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-Problem-encountered-in-stitching-merging-the-raster-files-tp5159338.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140831/701cb8f4/attachment.html>
