[gdal-dev] VICAR format
Even Rouault
even.rouault at spatialys.com
Fri Dec 5 07:49:41 PST 2014
Le vendredi 05 décembre 2014 16:21:45, Sebastian Walter a écrit :
> Hi Even,
> On 12/05/14 15:18, Even Rouault wrote:
> > To ease a future integration, could you update the files with the
> > appropriate copyright notice and the standard X/MIT licence text used by
> > other GDAL files (provided you're allowed to release the code under that
> > licence) ?
> Thank you for pointing me on this.
> The driver is based on the ISIS and PDS drivers so I hopefully don't
> hurt the copyrights of the other author's driver code - as I pasted in
> the usual header together with my name.
It's fine. Technically you should retain the copyright line(s) if you derive a
file from an existing one, but as you did is fine.
vicarkeywordhandler.h would also need copyright+licence.
http://www.spatialys.com
