[gdal-dev] IO Overhead when reading small subsets from Global Files
Julian Zeidler
gdal at zeidlers.de
Mon Dec 8 01:44:41 PST 2014
Dear Gdal-mailinglist,
I am currently trying to optimize a Global Modell.
The Modell reads small chunks (500x500) from lots (One for each day) of
Global Datasets (40000x20000)
These Dataset are compressed NetCDFs with a tilling activated (100x100).
(See output oif gdalinfo attached)
However when I measure the File-IO via NFS i get a Factor of ~10
compared to the uncompressed Output image when testing with gdal. Inside
teh Modell using the netCDF library diretyl i measure an even worst
Factor of ~60 compared to compressed outputs). This is better than using
untiled Inputs where the overhad was ~80x, but still a larger overhead
than I expected.
I tested it using gdal_translate in.nc out.tif -srcwin 6000 6000 500 500
Is there anything that can be done to decrease this Overhead?
For a global Modell Run the Overhead would add up to about 300TB*
*I am thankful for any suggestions.
Cheers Julian
Gdalinfo:
Driver: netCDF/Network Common Data Format
Files: LAI_Y2014_C10.nc
Size is 40320, 20160
Coordinate System is `'
Origin = (-179.999993460545994,90.000001090156800)
Pixel Size = (0.008928571482636,-0.008928571915164)
Metadata:
LAI#Fill_Value=-999
LAI#long_name=Leaf Area Index
LAI#units=m2/m2
LAI#valid_range={1,10}
latitude#long_name=Latitude
latitude#units=degrees_north
longitude#long_name=Longitude
longitude#units=degrees_east
NC_GLOBAL#comment=email:markus.tum at dlr.de
NC_GLOBAL#Conventions=CF-1.4
NC_GLOBAL#institution=DLR-DFD
NC_GLOBAL#title=10 Day LAI Composite based on Geoland2
Corner Coordinates:
Upper Left (-179.9999935, 90.0000011)
Lower Left (-179.9999935, -90.0000087)
Upper Right ( 180.0000087, 90.0000011)
Lower Right ( 180.0000087, -90.0000087)
Center ( 0.0000076, -0.0000038)
Band 1 Block=100x100 Type=Float32, ColorInterp=Undefined
NoData Value=-999
Metadata:
Fill_Value=-999
NETCDF_VARNAME=LAI
units=m2/m2
valid_range={1,10}
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141208/1a7fd269/attachment.html>
