[gdal-dev] GDALSuggestedWarpOutput() problem
joem at hiltonsoftware.com
Tue Dec 9 12:09:59 PST 2014
Hey everyone,
I am working on a tool to project FAA charts from Lambert Conformal Conic to
Web Mercator (EPSG 900913). It seems to be producing correct output except
for a FAA chart of the East Aleutian Islands. When I traced the problem
in my code, it appears that GDALSuggestedWarpOutput() is giving me a width
and height far too small given the input tiff had larger dimensions. The
source GeoTiff has dimensions of 15555x5786 but GDALSuggestedWarpOutput()
gives a suggested width of 17050 and a height of 178. A height of 178
pixels surely has to be wrong. I have added the well-known text and
proj.4 output from gdalinfo.exe of the input tiff below. Although I am
not entirely sure if I should, I have been using the values supplied by
GDALSuggestedWarpOutput() for creating my output Geotiff as if the output
will always be valid.
* Why is GDALSuggestedWarpOutput() giving bad values for the width and
height of the output tiff?
* Is this incorrect usage of GDALSuggestedWarpOutput() or is it a bug?
PROJ.4 : '+proj=lcc +lat_1=54.66666666666666 +lat_2=49.33333333333334
+lat_0=52.16666666666666 +lon_0=-177.5 +x_0=0 +y_0=0 +datum=NAD83 +units=m
+no_defs '
OGC WKT :
PROJCS["unnamed",
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.2572221010002,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4269"]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",54.66666666666666],
PARAMETER["standard_parallel_2",49.33333333333334],
PARAMETER["latitude_of_origin",52.16666666666666],
PARAMETER["central_meridian",-177.5],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
