[gdal-dev] gdalwarp/info failure on jp2 in secure AWS environment
Even Rouault even.rouault at spatialys.com
Wed Dec 10 01:51:07 PST 2014
Le mercredi 10 décembre 2014 00:08:35, Robert Coup a écrit :
> Does "gdalinfo --debug on --config CPL_CURL_VERBOSE YES ..." show 2x
> requests?
> I think the problem likely is the S3 signature is only valid for one
> file/url, not the corresponding .jp2.aux.xml file, so the request for the
> latter fails. Not sure of an easy way to fix that without writing a
> vsicurls3 module that can do the signing...
> Though JP2 supports storing coordinate information (bounds) in the file,
> just not the projection details - not sure if you could work around that?
The problem might also be the use of "--config GDAL_DISABLE_READDIR_ON_OPEN
EMPTY_DIR". As its name (hopefully) implies it means that the listing of the
directory where the main file is will be returned as empty. So no .aux.xml file,
or any auxiliary side files, will be ever tried to be read.
Even
> Rob :)
> On Wed, Dec 10, 2014 at 8:37 AM, MWilson Matthew <MWilson at edrnet.com> wrote:
> >  Good afternoon,
> >   I’ve been trying to track down some intermittent failures and I believe
> > I’ve come across something.  I was able to run the gdalinfo command on
> > imagery on s3 using a presigned url, vsicurl, and the following options:
> >  --config GDAL_HTTP_UNSAFESSL YES --config GDAL_DISABLE_READDIR_ON_OPEN
> > EMPTY_DIR --config CPL_VSIL_CURL_USE_HEAD NO
> >   However, I did note today that running the gdalinfo command on a jp2
> >   did
> > not return the coordinate information against an s3 image that required a
> > presigned url.  Running it against another s3 instance that does not
> > require a presigned url resulted in the full coordinate/projection
> > information being visible.
> >   As another test, I ran the gdalinfo command against a tif file on the
> > presigned url instance, and that also worked.
> >   To me, this means that there is a limitation in how gdal is reading the
> > images on s3 when a presigned url is required to get at them,
> > specifically, the auxiliary files aren’t being read.  This does kind of
> > make sense because the geotiff would have that information in the header
> > if I’m not mistaken, and the jp2 would not.
> >   Would anyone on the list have come across this before?  Does this make
> > sense?
> > Thanks,
> > Matthew
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
