[gdal-dev] Parse GML without geometry
Steve.Toutant at inspq.qc.ca
Fri Dec 12 13:13:02 PST 2014
Got it! Lots of fun!
Good links for python
http://pcjericks.github.io/py-gdalogr-cookbook/vector_layers.html#get-wfs-layer-and-iterate-over-features
Thousand thanks
Even Rouault <even.rouault at spatialys.com>@lists.osgeo.org
Envoyé par : gdal-dev-bounces at lists.osgeo.org
2014-12-12 15:42
A
gdal-dev at lists.osgeo.org
cc
Objet
Re: [gdal-dev] Parse GML without geometry
Le vendredi 12 décembre 2014 21:38:06, Steve.Toutant at inspq.qc.ca a écrit :
> thanks Kyle
> I ended up with
> geom=osgeo.ogr.CreateGeometryFromGML(wfs_response)
> Returns ERROR 1: Unrecognised geometry type <FeatureCollection>
> If I understand well, I think my question now is
> How do I parse the feature collection with ogr?
With the WFS driver:
ogrinfo "WFS:
http://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&REQUEST=GetFeature&version=1.1.0&Typename=continents&maxfeatures=10&propertyname=(NA2DESC)
" -ro -al
You can read the OGR API tutorial to see how to use a OGR datasource,
layer, feature
Regarding gemetry or not geometry, it won't matter. Actually as generated
by mapserver, there's a geometry column declared, but not filled. Won't be
an issue:
$ wget "
http://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&REQUEST=DescribeFeatureType&VERSION=1.1.0&TYPENAME=continents&
" -O -
<schema
targetNamespace="http://mapserver.gis.umn.edu/mapserver"
xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns="http://www.w3.org/2001/XMLSchema"
xmlns:gml="http://www.opengis.net/gml"
elementFormDefault="qualified" version="0.1" >
<import namespace="http://www.opengis.net/gml"
schemaLocation="
http://schemas.opengis.net/gml/3.1.1/base/gml.xsd" />
<element name="continents"
type="ms:continentsType"
substitutionGroup="gml:_Feature" />
<complexType name="continentsType">
<complexContent>
<extension base="gml:AbstractFeatureType">
<sequence>
<element name="msGeometry" type="gml:GeometryPropertyType"
minOccurs="0" maxOccurs="1"/>
<element name="NA2DESC" type="string"/>
<element name="NA3DESC" type="string"/>
</sequence>
</extension>
</complexContent>
</complexType>
</schema>
> Kyle Shannon <kyle at pobox.com>
> 2014-12-12 14:47
> A
> cc
> GDAL Developers <gdal-dev at lists.osgeo.org>
> Objet
> Steve,
> On Fri, Dec 12, 2014 at 12:35 PM, <Steve.Toutant at inspq.qc.ca> wrote:
> > Hi,
> > I need to parse the GML returned by this query, to make a list of
unique
> > value of NA2DESC tag using python
> > I could not make it with a XML parser yet. I consider using ogr API
but
> can
> > I use it even if there is no geometry?
> This one has a geometry, or so ogr thinks so:
> kyle at kyle-workstation:~$ ogrinfo -so -al -ro
"/vsicurl_streaming/http://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&REQUE
> =(NA2DESC)" INFO: Open of
`/vsicurl_streaming/http://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&REQUE
> =(NA2DESC)' using driver `GML' successful.
> Layer name: continents
> Geometry: Unknown (any)
> Feature Count: 10
> Extent: (-90.000000, -180.000000) - (83.627419, 180.000000)
> Layer SRS WKT:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4326"]]
> Geometry Column = msGeometry
> gml_id: String (0.0)
> NA2DESC: String (0.0)
> NA3DESC: String (0.0)
> > If ogr api is a good option, any link to examples or tutorial would be
> > appreciated since I never used the API.
> API tutorials:
> For gdal 2.x:
> http://gdal.org/ogr_apitut.html
> For gdal 1.x (the vector side is ogr):
> http://gdal.org/1.11/ogr/ogr_apitut.html
> > Thanks!
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> kss
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141212/4cebc88b/attachment-0001.html>
