[gdal-dev] GDAL Utilities: Keeping output format identical to input format
Zoltan Szecsei zoltans at geograph.co.za
Mon Dec 15 02:27:13 PST 2014
I've got a few GeoTiffs which have malformed projection/CRS data in them.
I also have ones with the correct data in them.
I would like to replace the malformed projection info with the correct
one, _without having the original bands re-sampled in any way whatsoever_.
If I use gdal_translate -a_srs +proj="tmerc wadda wadda" tiffbad
tiffgood, is there a way to keep the bands identical to the input tiff file?
(Maybe someone has written a utility to strip this info out of a 'good'
image, and set it for use in gdal_translate?)
In a similar vein, using gdaladdo to build pyramids does leave the
original bands untouched and simply adds the newly calculated overviews
to the tiff image, does it not?
TIA,
Regards,
Zoltan
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax:    +27-86-6115323     www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141215/dce01c63/attachment.html>
