[gdal-dev] importing GML with geometry of many parts
    Piotr Pachół
    piotrpachol at gmail.com
    Tue Dec 16 07:03:16 PST 2014
W dniu 2014-12-15 14:57, Even Rouault pisze:
> Le lundi 15 décembre 2014 14:46:06, Piotr Pachół a écrit :
>> Hello,
>> I have gml file with  geometries of different types (Points, Lines,
>> Polygons)
>> I try to import it into PostGIS with this command:
>> ogr2ogr -a_srs EPSG:2180 -f "PostgreSQL" PG:"host=localhost
>> user=postgres dbname=test password=*** port=5432" c:\test.xml -nlt
>> PROMOTE_TO_MULTI
>> Almost everything works OK except  objects like that:
>> <gml:featureMember>
>>     <KR>
>>       <bt:kod>0010_803</bt:kod>
>>       <bt:geometria>
>>         <gml:LineString gml_id="ID_1" srsName="EPSG:2180" srsDimension="2">
>>               <gml:posList>479444.04 317832.37 479447.99 317823.28
>> </gml:posList>
>>         </gml:LineString>
>>       </bt:geometria>
>>       <bt:geometria>
>>         <gml:LineString gml_id="ID_2" srsName="EPSG:2180" srsDimension="2">
>>               <gml:posList>479659.15 318668.28 479695.28 318671.1
>> </gml:posList>
>>         </gml:LineString>
>>       </bt:geometria>
>>     </KR>
>> </gml:featureMember>
> Piotr,
> Hum, this is an annoying form of GML with several geometry fields AND with the
> same name... GDAL 1.11 should normally be able to support multiple geometry
> fields, but in that case, that will not work as they have the same name.
> In fact, you might want to try instead an older trick, quite experimental and
> not officially documented. Try setting GML_FETCH_ALL_GEOMETRIES=YES as
> configuration option/environment variable
> OGR 1.8.0 adds support to "merge" the multiple geometries found in a feature
> by
> setting the configuration option <b>GML_FETCH_ALL_GEOMETRIES</b> to <b>YES</b>.
> The geometries
> will be collected into a GeometryCollection (or Multipolygon if individual
> geometries
> are polygons or multipolygons). This can be useful when reading some GML
> application profiles.
> If a <GeometryElementPath> element is specified in the .gfs, the fetching
> will be limited
> to paths that match the value of <GeometryElementPath>.<p>
> Even
Even,
Thank you very much.
With setting GML_FETCH_ALL_GEOMETRIES=YES all parts of geometry
are imported correctly creating in PostGIS "GeometryCollection" type.
Regards,
Piotr
>> In above example object consists of 2 parts and only second part of
>> geometry(gml_id="ID_2") is imported to PostGIS.
>> What should I do to import all the parts of the geometry of an object?
>> Regards,
>> Piotr
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
