[gdal-dev] Can't make GME driver work
Wolf Bergenheim
wolf+grass at bergenheim.net
Fri Dec 19 09:33:35 PST 2014
Hi Jorge.
I noticed some issues with it earlier this week. I'll see if I have some
spare time over the weekend to see what I can do about it. Are you using
the trunk version or an earlier release?
On 18 December 2014 at 23:23, Jorge Arévalo <jorge at cartodb.com> wrote:
> Hello,
> I'm having problems making the GDAL GME driver work (
> http://trac.osgeo.org/gdal/wiki/GMEDriver). I've defined CLIENT_API and
> CLIENT_SECRET in Google API console, and I successfully used them with the
> QGIS GME plugin (
> https://plugins.qgis.org/plugins/GoogleMapsEngineConnector/) and with the
> example Python script of the doc page:
> https://developers.google.com/maps-engine/documentation/oauth/installedapplication.
> But, for some reason, I keep getting HTTP 401 error when trying to read
> from my GME account using the GDAL driver.
> I've used gdal_auth.py to get the access token and the refresh token.
> Passed the config options, as stated in the driver's page. Always getting
> HTTP 401.
> Do you have any working example using GDAL GME driver? More info about my
> problem here:
> http://gis.stackexchange.com/questions/127065/i-cant-configure-authentication-with-google-maps-engine-driver-from-gdal
> Many thanks in advance!
> Jorge
> Sent using Postbox:
> http://www.getpostbox.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141219/93196b71/attachment.html>
