[gdal-dev] editing NetCDF size using GDAL in C++ code
Benedetta Onori benedetta.onori at gmail.com
Thu Feb 6 07:05:10 PST 2014
In the creation of a NetCDF I treat subsets as bands.
with gdalinfo I get this:
Subdatasets:
  SUBDATASET_1_NAME=NETCDF:"myfile.nc":Band1
  SUBDATASET_1_DESC=[10000x1] Band1 (64-bit floating-point)
  SUBDATASET_2_NAME=NETCDF:"myfile.nc":Band2
  SUBDATASET_2_DESC=[10000x1] Band2 (64-bit floating-point)
  SUBDATASET_3_NAME=NETCDF:"myfile.nc":Band3
  SUBDATASET_3_DESC=[10000x1] Band3 (64-bit floating-point)
  SUBDATASET_4_NAME=NETCDF:"myfile.nc":Band4
  SUBDATASET_4_DESC=[10000x1] Band4 (64-bit floating-point)
<gdal-dev at lists.osgeo.org>
So it recognizes bands as netcdf subsets, but with Create( ) only one size
for all bands is possible and not different sizes for different
bands-subsets.
2014-02-06 Etienne Tourigny <etourigny.dev at gmail.com>:
> What do you mean by subsets?  Do you mean datasets (known as variables in
> netcdf terminology)? If so, there is no way the netcdf driver can create a
> netcdf file with subdatasets, sorry.
> A workaround is to use gdal to create a file for each subdataset and then
> merge them with the nco commandline tools (e.g. ncks -A file1.nc file2.nc
> cheers, Etienne
> On Thu, Feb 6, 2014 at 10:22 AM, Benedetta Onori <
> benedetta.onori at gmail.com> wrote:
>> Hi all,
>> I have a question about NetCDF writing using GDAL.
>> The netcdf driver doesn't support the option GA_Update used to edit
>> dataset, but only GA_ReadOnly.
>> My question is: during the creation of a new netCDF dataset, how can I differentiate
>> the sizes of different subsets?
>> (For example the subset 1 must be 100x100, subset 2 100x1, ...etc...)
>> Thank you for the attention
>> Regards
>> b.o.
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140206/cc17cf14/attachment.html>
