[gdal-dev] Can not open bigtiff file using gdal1.10 API saved by photoshop cs6
ridge wang
ridgewang at gmail.com
Thu Feb 27 15:22:39 PST 2014
Even,
Sorry for reply so late. I create a tickets as
http://trac.osgeo.org/gdal/ticket/5403. I attached 2 tiff files, one can
opend by gdal and the other cannot. But they all can opend by photoshop
correctly. Both of these two original tiff file are created by gdal 1.10
and can reopen ok. The attached files are just filled all pixels to black
and saved by photoshop cs6. Can you give me some suggestions and is there
some utilities to repair these tiff files? thanks.
Ridge
On Wed, Feb 26, 2014 at 10:24 AM, ridgewang <ridgewang at gmail.com> wrote:
> Hi,
> I have created a bigtiff file with over 3GB filesize using gdal 1.10 API
> , then I do some simple edition and save the result tiff image using
> photoshop cs6. Now I cannot open the result tiff file saved by ps cs 6
> using gdal api, it reports that interger overflow and cannot process zero
> stripsize. As well photoshop cs6 can open the result bigtiff file.
> Thanks in advance for any tips!
> Ridge
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140228/74e45d06/attachment.html>
