[gdal-dev] Standard Dev. Environment?
Jay L.
jlaura at asu.edu
Fri Jan 10 06:14:19 PST 2014
Frank,
Thanks for the heads up. I am using the --without-jasper flag as part of
the ./configure call. Here is the error that I am seeing - that led to me
to believe that the issue is jasper related:
make[1]: Entering directory `/home/vagrant/gdal-1.10.1/apps'
g++ gdalinfo.o commonutils.o -L/home/vagrant/gdal-1.10.1 -lgdal
-lpthread -lm -lrt -ldl -o gdalinfo
/home/vagrant/gdal-1.10.1/libgdal.so: undefined reference to `dec_jpeg2000'
collect2: ld returned 1 exit status
make[1]: *** [gdalinfo] Error 1
make[1]: Leaving directory `/home/vagrant/gdal-1.10.1/apps'
make: *** [apps-target] Error 2
I did install libjpeg-dev and libjasper-dev in hopes that this would
alleviate the issue.
Perhaps I am pursuing the issue in the wrong direction?
Thanks,
Jay
On Thu, Jan 9, 2014 at 9:33 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Jay,
> Are you needing Jasper? Normally a default build ("./configure") should
> work pretty well on a precise system. I'm guessing you have enabled jasper
> because it is key to what you want to do? If not --without-jasper should
> be straight forward.
> Best regards,
> Frank
> On Thu, Jan 9, 2014 at 8:00 PM, Jay L. <jlaura at asu.edu> wrote:
>> List,
>> I wonder if a standard dev. environment exists? I am working to extend a
>> driver and am having trouble getting an environment working that will
>> compile. Current setup is a VagrantVM, Ubuntu 12.04 32-bit with source
>> downloaded from SVN. Attempting to build with minimized drivers<http://trac.osgeo.org/gdal/wiki/BuildingOnUnixWithMinimizedDrivers>as per the build documentation and am having build errors due to
>> dec_jpeg2000 (jasper I believe).
>> Q: Are devs using a standard environment (or a different flavor of *nix?)?
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140110/7b62b817/attachment.html>
