[gdal-dev] Standard Dev. Environment?
Even Rouault even.rouault at mines-paris.org
Fri Jan 10 06:24:33 PST 2014
Selon "Jay L." <jlaura at asu.edu>:
> Frank,
> Thanks for the heads up.  I am using the --without-jasper flag as part of
> the ./configure call.  Here is the error that I am seeing - that led to me
> to believe that the issue is jasper related:
> make[1]: Entering directory `/home/vagrant/gdal-1.10.1/apps'
> g++  gdalinfo.o commonutils.o  -L/home/vagrant/gdal-1.10.1 -lgdal
>  -lpthread -lm -lrt -ldl                  -o gdalinfo
> /home/vagrant/gdal-1.10.1/libgdal.so: undefined reference to `dec_jpeg2000'
> collect2: ld returned 1 exit status
> make[1]: *** [gdalinfo] Error 1
> make[1]: Leaving directory `/home/vagrant/gdal-1.10.1/apps'
> make: *** [apps-target] Error 2
> I did install libjpeg-dev and libjasper-dev in hopes that this would
> alleviate the issue.
> Perhaps I am pursuing the issue in the wrong direction?
When you run ./configure several times, make sure to run "make clean" between
the attempts. I'm not clear why you've had this error with the "dec_jpeg2000"
symbol that is defined and used in the GRIB driver (it has a definition even if
you don't have Jasper). Anway the "make clean" will probably solve it.
Generally, "./configure" without any particular argument should work on most
platforms.
> Thanks,
> Jay
> On Thu, Jan 9, 2014 at 9:33 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > Jay,
> > Are you needing Jasper?  Normally a default build ("./configure") should
> > work pretty well on a precise system. I'm guessing you have enabled jasper
> > because it is key to what you want to do?  If not --without-jasper should
> > be straight forward.
> > Best regards,
> > Frank
> > On Thu, Jan 9, 2014 at 8:00 PM, Jay L. <jlaura at asu.edu> wrote:
> >> List,
> >> I wonder if a standard dev. environment exists?  I am working to extend a
> >> driver and am having trouble getting an environment working that will
> >> compile.  Current setup is a VagrantVM, Ubuntu 12.04 32-bit with source
> >> downloaded from SVN.  Attempting to build with minimized
> drivers<http://trac.osgeo.org/gdal/wiki/BuildingOnUnixWithMinimizedDrivers>as
> per the build documentation and am having build errors due to
> >> dec_jpeg2000 (jasper I believe).
> >> Q: Are devs using a standard environment (or a different flavor of *nix?)?
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > I set the clouds in motion - turn up   | Frank Warmerdam,
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush    | Geospatial Software Developer
