[gdal-dev] Standard Dev. Environment?
Jay L.
jlaura at asu.edu
Fri Jan 10 07:49:51 PST 2014
Evan,
Thanks for the info. One more question for you - make clean worked, but I
have hit another issue:
After running `./configure --without-jpeg ...`, `make clean`, `sudo make
install`:
/home/vagrant/gdal-1.10.1/libgdal.so: undefined reference to
`jpeg_write_scanlines'
`jpeg_CreateCompress'
`jpeg_read_scanlines'
So lib-jpeg is seen. This doesn't make sense since I have --without-jpeg
specified in the config. I looked in the config and must have missed it -
does a flag to specify the full PATH to libjpeg exist?
Thanks,
Jay
On Fri, Jan 10, 2014 at 7:24 AM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Selon "Jay L." <jlaura at asu.edu>:
> > Frank,
> > Thanks for the heads up. I am using the --without-jasper flag as part of
> > the ./configure call. Here is the error that I am seeing - that led to
> me
> > to believe that the issue is jasper related:
> > make[1]: Entering directory `/home/vagrant/gdal-1.10.1/apps'
> > g++ gdalinfo.o commonutils.o -L/home/vagrant/gdal-1.10.1 -lgdal
> > -lpthread -lm -lrt -ldl -o gdalinfo
> `dec_jpeg2000'
> > collect2: ld returned 1 exit status
> > make[1]: *** [gdalinfo] Error 1
> > make[1]: Leaving directory `/home/vagrant/gdal-1.10.1/apps'
> > make: *** [apps-target] Error 2
> > I did install libjpeg-dev and libjasper-dev in hopes that this would
> > alleviate the issue.
> > Perhaps I am pursuing the issue in the wrong direction?
> When you run ./configure several times, make sure to run "make clean"
> between
> the attempts. I'm not clear why you've had this error with the
> "dec_jpeg2000"
> symbol that is defined and used in the GRIB driver (it has a definition
> even if
> you don't have Jasper). Anway the "make clean" will probably solve it.
> Generally, "./configure" without any particular argument should work on
> most
> platforms.
> > Thanks,
> > Jay
> > On Thu, Jan 9, 2014 at 9:33 PM, Frank Warmerdam <warmerdam at pobox.com>
> wrote:
> > > Jay,
> > > Are you needing Jasper? Normally a default build ("./configure")
> should
> > > work pretty well on a precise system. I'm guessing you have enabled
> jasper
> > > because it is key to what you want to do? If not --without-jasper
> should
> > > be straight forward.
> > > Best regards,
> > > Frank
> > > On Thu, Jan 9, 2014 at 8:00 PM, Jay L. <jlaura at asu.edu> wrote:
> > >> List,
> > >> I wonder if a standard dev. environment exists? I am working to
> extend a
> > >> driver and am having trouble getting an environment working that will
> > >> compile. Current setup is a VagrantVM, Ubuntu 12.04 32-bit with
> source
> > >> downloaded from SVN. Attempting to build with minimized
> > drivers<
> http://trac.osgeo.org/gdal/wiki/BuildingOnUnixWithMinimizedDrivers>as
> > per the build documentation and am having build errors due to
> > >> dec_jpeg2000 (jasper I believe).
> > >> Q: Are devs using a standard environment (or a different flavor of
> *nix?)?
> > >> _______________________________________________
> > >> gdal-dev mailing list
> > >> gdal-dev at lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > > I set the clouds in motion - turn up | Frank Warmerdam,
> > > light and sound - activate the windows | http://pobox.com/~warmerdam
> > > and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140110/2ebf8d47/attachment-0001.html>
