[gdal-dev] gdalinfo coordinates problem?
Even Rouault even.rouault at mines-paris.org
Fri Jan 17 14:37:28 PST 2014
Le vendredi 17 janvier 2014 21:28:35, Reynolds, Scott a écrit :
> Hi,
> I've downloaded several DEMs (e.g 27002570PAS_dem.zip) from
> ftp://pamap.pasda.psu.edu/pamap_lidar/cycle1/DEM/South/2008/20000000/.
> Gdalinfo is reporting the corner coordinates to be in the vicinity of  91
> degrees 31 minutes west longitude which should be more like 75 degrees 36
> minutes west longitude.  Can someone explain what is happening here?
GeoTIFF support for non-meter linear units has been a major source of
headaches in GDAL / libgeotiff. People will appreciate looking at
frmts/gtiff/gt_wkt_srs.cpp
I'm not sure if that GeoTIFF file is correct or not regarding the values of the
false easting/northing with respect to the GeoTIFF spec (many in the wild are
broken), but when looking at what happens, I noticed that a transformation
from meters to feet happened twice. The attached patch fixes that (and the
corner coordinates are around 75°), but I'm not sure if it is completely
correct in all cases.
You should likely create a GDAL Trac ticket with your report and the patch,
but I'm not sure who will dare hurting his head against this wall...
Even
> Thanks,
> Scott
Geospatial professional services
http://even.rouault.free.fr/services.html
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140117/2dc50e67/attachment.bin>
