[gdal-dev] gdalinfo coordinates problem?
Dmitriy Baryshnikov bishop.dev at gmail.com
Fri Jan 17 13:52:27 PST 2014
yes, this is a bug. The same error on last trunk gdal and also QGIS.
I think the problem is in reprojection (lost linear units). The file
have linear unit as us_survey_feet (0.304801).
It's interesting does gdal support such projection? May be is is
unsupported.
Best regards,
     Dmitry
18.01.2014 0:28, Reynolds, Scott ?????:
> Hi,
> I've downloaded several DEMs (e.g 27002570PAS_dem.zip) from
> ftp://pamap.pasda.psu.edu/pamap_lidar/cycle1/DEM/South/2008/20000000/.
> Gdalinfo is reporting the corner coordinates to be in the vicinity of
>  91 degrees 31 minutes west longitude which should be more like 75
> degrees 36 minutes west longitude.  Can someone explain what is
> happening here?
> Thanks,
> Scott
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140118/1ac42172/attachment.html>
