[gdal-dev] GDAL v1.10.1 - Bad output from gdalwarp (works with 1.10.0)
Jason Greenlaw - NOAA Affiliate jason.greenlaw at noaa.gov
Wed Jan 22 13:09:33 PST 2014
Even,
Thank you for catching the quote problem.  I've fixed my WKT accordingly.
Unfortunately altering the SRS to GDAL's default EPSG:3857 definition
results in the same alignment problem when viewed in ArcGIS Desktop/Server,
so I altered it back to my custom WKT (using double quotes this time) - now
it's aligning properly again, but I'm still seeing the same error:
    ERROR 6: No translation for Mercator_Auxiliary_Sphere to PROJ.4 format
is known.
It still produces valid output with 1.10.0, but with 1.10.1 it still exits
prematurely with status 1 and produces an all-zero image.
It seems that something was changed between 1.10.0 and 1.10.1 that made
this a fatal error.
Thanks,
Jason
On Wed, Jan 22, 2014 at 3:07 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Le mercredi 22 janvier 2014 20:27:19, Jason Greenlaw - NOAA Affiliate a
> écrit :
> > When attempting to use a polygon shapefile (in custom web mercator
> > projection) with the gdalwarp cutline operation, operating on a GeoTIFF
> > (with same projection), the following error is output in both versions
> > 1.10.0 and 1.10.1:
> >     ERROR 6: No translation for 'Mercator_Auxiliary_Sphere' to PROJ.4
> > format is known.
> The issue is that esri-3857.prf contains single quote characters instead of
> double quotes, and oceans_glakes_50m_3857.prj contain single quotes inside
> double quotes. Both are not valid AFAIK
> You should be able to overcome this with :
> ogr2ogr -a_srs EPSG:3857 oceans_glakes_50m_3857.shp
> oceans_glakes_50m_3857_fixed.shp
> and
> gdalwarp -s_srs EPSG:4326 -t_srs EPSG:3857 -r bilinear -srcnodata
>  9999.0 -dstnodata 9999.0 -tr 4000 9000 -overwrite -co COMPRESS=LZW -co
> TILED=yes sst.flt sst_projected.tif
> > With GDAL 1.10.0, the operation still completes successfully with a zero
> > exit status, but with GDAL 1.10.1 the operation fails with a nonzero exit
> > status, and the resulting GeoTIFF has zeros for all pixels.
> > Here is the command I'm using:
> >     gdalwarp -co COMPRESS=LZW -cutline oceans_glakes_50m_3857.shp
> > -srcnodata 9999.0 -dstnodata 9999.0 -overwrite sst_global.tif
> > sst_global_cut.tif
> > The input shapefile was produced by reprojecting with ogr2ogr from
> > EPSG:4326 to my custom projection (WKT is included below), which is
> stored
> > in a *.prf file.  The source GeoTIFF is single-band with Float32 pixel
> > type.
> > The custom WKT can be found here:
> http://jgreenlaw.org/gdal/esri-3857.prf
> > The cutline shapefile can be downloaded at:
> > http://jgreenlaw.org/gdal/oceans_glakes_50m_3857.tar.gz (900kb)
> > The source GeoTIFF can be generated from this FLT/HDR raster:
> > http://jgreenlaw.org/gdal/sst_flt.tar.gz (11mb) by running these
> commands:
> >     gdalwarp -s_srs EPSG:4326 -t_srs esri-3857.prf -r bilinear -srcnodata
> >     gdalwarp -co COMPRESS=LZW -te -20037507.0671618 -19971868.8804086
> > 20037507.0671618 19971868.8804086 -srcnodata 9999.0 -dstnodata 9999.0 -tr
> > 4000 9000 sst_projected.tif sst_global.tif
> > Does anyone know if this behavior is to be expected when the above error
> is
> > output?  Is there a better method for reprojecting to Web Mercator that
> > will align properly in ArcGIS?
> > Thanks
> > -Jason
> > Background:
> > The reason for using custom WKT for reprojecting to Web Mercator is
> because
> > I have experienced alignment problems displaying GDAL-produced GeoTIFFs
> in
> > ArcGIS when reprojecting using "EPSG:3857" as the target SRS (this seems
> to
> > be related to http://trac.osgeo.org/gdal/ticket/3962).
> > I generated the WKT below by copying the 102113 definition in
> > $GDAL_DATA/esri_extra.wkt and merging information from an ESRI Web
> Mercator
> > *.prj file.  Using this custom WKT as the target SRS with gdalwarp
> normally
> > results in rasters that align properly with ArcGIS Web Mercator data
> > (without on-the-fly datum transformation).
> > ------------------- Custom WKT for reprojecting to ESRI Web Mercator
> using
> > GDAL (
> > http://jgreenlaw.org/gdal/esri-3857.prf):
> > PROJCS['WGS_1984_Web_Mercator_Auxiliary_Sphere',
> >     GEOGCS['GCS_WGS_1984',
> >         DATUM['D_WGS_1984',
> >             SPHEROID['WGS_1984',6378137.0,298.257223563]
> >         PRIMEM['Greenwich',0.0],
> >         UNIT['Degree',0.0174532925199433]
> >     PROJECTION['Mercator_Auxiliary_Sphere'],
> >     PARAMETER['False_Easting',0.0],
> >     PARAMETER['False_Northing',0.0],
> >     PARAMETER['Central_Meridian',0.0],
> >     PARAMETER['latitude_of_origin',0.0],
> >     PARAMETER['Standard_Parallel_1',0.0],
> >     PARAMETER['Auxiliary_Sphere_Type',0.0],
> >     UNIT['Meter',1.0],
> >     EXTENSION["PROJ4",
> >         "+proj=merc +a=6378137 +b=6356752.314245179 +lat_ts=0.0
> +lon_0=0.0
> > +x_0=0.0 +y_0=0.0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"
> >     AUTHORITY["EPSG","3857"]
> Geospatial professional services
> http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140122/f970cfae/attachment.html>
