[gdal-dev] GDAL v1.10.1 - Bad output from gdalwarp (works with 1.10.0)
Even Rouault
even.rouault at mines-paris.org
Wed Jan 22 13:18:07 PST 2014
Le mercredi 22 janvier 2014 22:09:33, Jason Greenlaw - NOAA Affiliate a écrit :
> Even,
> Thank you for catching the quote problem. I've fixed my WKT accordingly.
> Unfortunately altering the SRS to GDAL's default EPSG:3857 definition
> results in the same alignment problem when viewed in ArcGIS Desktop/Server,
> so I altered it back to my custom WKT (using double quotes this time) - now
> it's aligning properly again, but I'm still seeing the same error:
> ERROR 6: No translation for Mercator_Auxiliary_Sphere to PROJ.4 format
> is known.
Yes, this is an issue. Nobody agrees on how to represent WebMercator in WKT.
There's a ticket pending in Trac about that.
While looking at the .prj, I see a difference in the EXTENSION["PROJ4" node
w.r.t what GDAL does.
The .prj has :
"+proj=merc +a=6378137 +b=6356752.314245179 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
+y_0=0.0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"
Whereas gdalsrsinfo EPSG:3857 shows :
"+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
So the ESRI stuff uses a non-spheric ellipsoid, which I believe is wrong...
You can probably get the same result as ESRI by using the "+proj=merc
+a=6378137 +b=6356752.314245179 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0.0
+k=1.0 +units=m +nadgrids=@null +wktext +no_defs" as -a_srs value.
> It still produces valid output with 1.10.0, but with 1.10.1 it still exits
> prematurely with status 1 and produces an all-zero image.
> It seems that something was changed between 1.10.0 and 1.10.1 that made
> this a fatal error.
I don't see anything obvious in the log that explain the behavioural change,
but erroring out make sense when there's an error... So 1.10.1 behaviour seems
OK.
> Thanks,
> Jason
> On Wed, Jan 22, 2014 at 3:07 PM, Even Rouault
> <even.rouault at mines-paris.org>wrote:
> > Le mercredi 22 janvier 2014 20:27:19, Jason Greenlaw - NOAA Affiliate a
> > écrit :
> > > When attempting to use a polygon shapefile (in custom web mercator
> > > projection) with the gdalwarp cutline operation, operating on a GeoTIFF
> > > (with same projection), the following error is output in both versions
> > > 1.10.0 and 1.10.1:
> > > ERROR 6: No translation for 'Mercator_Auxiliary_Sphere' to PROJ.4
> > > format is known.
> > The issue is that esri-3857.prf contains single quote characters instead
> > of double quotes, and oceans_glakes_50m_3857.prj contain single quotes
> > inside double quotes. Both are not valid AFAIK
> > You should be able to overcome this with :
> > ogr2ogr -a_srs EPSG:3857 oceans_glakes_50m_3857.shp
> > oceans_glakes_50m_3857_fixed.shp
> > and
> > gdalwarp -s_srs EPSG:4326 -t_srs EPSG:3857 -r bilinear -srcnodata
> > 9999.0 -dstnodata 9999.0 -tr 4000 9000 -overwrite -co COMPRESS=LZW -co
> > TILED=yes sst.flt sst_projected.tif
> > > With GDAL 1.10.0, the operation still completes successfully with a
> > > zero exit status, but with GDAL 1.10.1 the operation fails with a
> > > nonzero exit status, and the resulting GeoTIFF has zeros for all
> > > pixels.
> > > Here is the command I'm using:
> > > gdalwarp -co COMPRESS=LZW -cutline oceans_glakes_50m_3857.shp
> > > -srcnodata 9999.0 -dstnodata 9999.0 -overwrite sst_global.tif
> > > sst_global_cut.tif
> > > The input shapefile was produced by reprojecting with ogr2ogr from
> > > EPSG:4326 to my custom projection (WKT is included below), which is
> > stored
> > > in a *.prf file. The source GeoTIFF is single-band with Float32 pixel
> > > type.
> > > The custom WKT can be found here:
> > http://jgreenlaw.org/gdal/esri-3857.prf
> > > The cutline shapefile can be downloaded at:
> > > http://jgreenlaw.org/gdal/oceans_glakes_50m_3857.tar.gz (900kb)
> > > The source GeoTIFF can be generated from this FLT/HDR raster:
> > > http://jgreenlaw.org/gdal/sst_flt.tar.gz (11mb) by running these
> > commands:
> > > gdalwarp -s_srs EPSG:4326 -t_srs esri-3857.prf -r bilinear
> > > -srcnodata
> > > gdalwarp -co COMPRESS=LZW -te -20037507.0671618 -19971868.8804086
> > > 20037507.0671618 19971868.8804086 -srcnodata 9999.0 -dstnodata 9999.0
> > > -tr 4000 9000 sst_projected.tif sst_global.tif
> > > Does anyone know if this behavior is to be expected when the above
> > > error
> > is
> > > output? Is there a better method for reprojecting to Web Mercator that
> > > will align properly in ArcGIS?
> > > Thanks
> > > -Jason
> > > Background:
> > > The reason for using custom WKT for reprojecting to Web Mercator is
> > because
> > > I have experienced alignment problems displaying GDAL-produced GeoTIFFs
> > in
> > > ArcGIS when reprojecting using "EPSG:3857" as the target SRS (this
> > > seems
> > to
> > > be related to http://trac.osgeo.org/gdal/ticket/3962).
> > > I generated the WKT below by copying the 102113 definition in
> > > $GDAL_DATA/esri_extra.wkt and merging information from an ESRI Web
> > Mercator
> > > *.prj file. Using this custom WKT as the target SRS with gdalwarp
> > normally
> > > results in rasters that align properly with ArcGIS Web Mercator data
> > > (without on-the-fly datum transformation).
> > > ------------------- Custom WKT for reprojecting to ESRI Web Mercator
> > using
> > > GDAL (
> > > http://jgreenlaw.org/gdal/esri-3857.prf):
> > > PROJCS['WGS_1984_Web_Mercator_Auxiliary_Sphere',
> > > GEOGCS['GCS_WGS_1984',
> > > DATUM['D_WGS_1984',
> > > SPHEROID['WGS_1984',6378137.0,298.257223563]
> > > PRIMEM['Greenwich',0.0],
> > > UNIT['Degree',0.0174532925199433]
> > > PROJECTION['Mercator_Auxiliary_Sphere'],
> > > PARAMETER['False_Easting',0.0],
> > > PARAMETER['False_Northing',0.0],
> > > PARAMETER['Central_Meridian',0.0],
> > > PARAMETER['latitude_of_origin',0.0],
> > > PARAMETER['Standard_Parallel_1',0.0],
> > > PARAMETER['Auxiliary_Sphere_Type',0.0],
> > > UNIT['Meter',1.0],
> > > EXTENSION["PROJ4",
> > +lon_0=0.0
> > > +x_0=0.0 +y_0=0.0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"
> > > AUTHORITY["EPSG","3857"]
> > Geospatial professional services
> > http://even.rouault.free.fr/services.html
