[gdal-dev] Fast Pixel Access
Brian Case rush at winkey.org
Fri Jan 31 15:23:13 PST 2014
evenr
what about the use of a tileindex? seems an intersection with a set of
polys first would be quick
brian
On Fri, 2014-01-31 at 19:30 +0100, Even Rouault wrote:
> Le vendredi 31 janvier 2014 17:15:53, David Baker (Geoscience) a écrit :
> > Dev's,
> > I have a set of 55,501 bil files in a single directory.  They are DEMS data
> > that cover the US in 7.5 minute tiles.  I would like to randomly access
> > elevations at a given lat/lon's from the whole dataset.  I created a vrt
> > file from the directory of bil files, and have been able to access the
> > elevation at a given lat/lon using gdallocationinfo, but because of the
> > size of the dataset, this operation is somewhat slow.  Can the vrt be
> > indexed?
> No, it isn't currently, although I think it could be improved to have a in-
> memory index with moderate effort.
> But are you sure the slowness is due to the lack of index ? 55,000 is a big
> number, but not that big. Maybe the slowness just comes from the opening time
> (XML parsing) of such a big VRT. That would need to be profiled to be sure
> where the bottleneck is.
> > Or, is there a faster, better way to access the pixels?  I would
> > first like to do this with the utilities before diving into code (C#).
> > The files are regularly named base on their location within a 1 arc-second
> > grid.
> > Thanks,
> > David
> > David M. Baker
> > Senior Advisor - Geoscience Technology
> > Chesapeake Energy Corporation
> > david.m.baker at chk.com<mailto:david.m.baker at chk.com>
> > ________________________________
> > This email (and attachments if any) is intended only for the use of the
> > individual or entity to which it is addressed, and may contain information
> > that is confidential or privileged and exempt from disclosure under
> > applicable law. If the reader of this email is not the intended recipient,
> > or the employee or agent responsible for delivering this message to the
> > intended recipient, you are hereby notified that any dissemination,
> > distribution or copying of this communication is strictly prohibited. If
> > you have received this communication in error, please notify the sender
> > immediately by return email and destroy all copies of the email (and
> > attachments if any).
> Geospatial professional services
> http://even.rouault.free.fr/services.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
