[gdal-dev] GSoC weekly report 8. GDAL Networking
Dmitry Baryshnikov
bishop.dev at gmail.com
Fri Jul 11 18:37:32 PDT 2014
Even hi,
As was noted Mikhail works under windows on QTCreator. There is no autoconf
on window and building python bindings is not trivial.
So I wrote cmake scripts which build fine on both (Linux/windows) os.
Yes, were is some limitations on windows: cannot build swig python bindings
on debug build. This is because linker required python and all it modules
compiled with debug support. But on release build everything is OK.
So the scenario is so: Mikhail develop gnm C methods for bindings and test
them on debug build. If them works fine, than write python bindings in
separate file (i.e. gnm.i) and try to compile on release build. Than
install the bindings and test them too.
Best regards,
Dmitry
11 июля 2014 г. 22:27 пользователь "Even Rouault" <
even.rouault at mines-paris.org> написал:
> Le vendredi 11 juillet 2014 20:21:36, Mikhail Gusev a écrit :
> > Hello everyone.
> > According to my plan this week I worked on automatic graph building in
> GNM.
> > See my blog post:
> http://gsoc2014gnm.blogspot.ru/2014/07/week-8-automatic-graph-building.html
> > I'm also still a bit blocked on python tests and bindings. I haven't
> > succeeded in building GDAL with python support using CMake. But I hope to
> > finish this the next week.
> Mikhail,
> why do you mention CMake ? Your tree
> https://github.com/MikhanGusev/gdal/commits/trunk is based on GDAL trunk,
> which uses autoconf.
> Anyway, you don't even need to ask for the python bindings at configure
> time.
> Building them should just be a matter of :
> cd swig/python
> python setup.py build
> And if you want to install them
> * system-wide: (sudo) python setup.py install
> * otherwise export PYTHONPATH=$PWD/build/lib.use_autocompletion
> Even
> Geospatial professional services
> http://even.rouault.free.fr/services.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140712/c395d965/attachment.html>
