[gdal-dev] gdal installation, geopdf not recognized
Eli Adam
eadam at co.lincoln.or.us
Mon Jul 14 10:40:08 PDT 2014
Hi Jian,
On Mon, Jul 14, 2014 at 7:52 AM, Liu, Jian <JLiu at eris.ca> wrote:
> Hello,
> I have been trying to install GDAL to convert USGS GeoPdf. Googling gave me
> a couple of links for quick installation for windows.
http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries lists some
additional options. I often use http://www.gisinternals.com/sdk/ from
Tamas.
> http://trac.osgeo.org/osgeo4w/wiki
> · http://www.lfd.uci.edu/~gohlke/pythonlibs/#gdal
> (GDAL‑1.11.0.win32‑py2.7.exe)
> I have 32 bit machine, windows 7 and python 2.7. There was a side-by-side
> configuration error, so I had to get that .dll, and I tried a couple of
> times. The installation seemed successful, however, I got error when reading
> a geopdf:
> ERROR 4: `C:\TestFolder\WI_Madison_West_20100723_TM_geo.pdf' not recognized
> as a supported file format.
I got this error from OSGeo4W too. The last two lines of this page,
http://trac.osgeo.org/osgeo4w/ticket/408, lists the mailing list and
ticket tracker. You can ask or report this error there. Searching
through trac for OSGeo4W, I found this which seems like it might be
similar, http://trac.osgeo.org/osgeo4w/ticket/408
If you list a link to the file, it is easier for people to test. I
found, this, ims.er.usgs.gov/gda_services/download?item_id=5954807 for
testing. I tested with about a four month old download from
http://www.gisinternals.com/sdk/ and it worked showing this,
gdalinfo WI_Madison_West_20130722_TM_geo.pdf
Driver: PDF/Geospatial PDF
Files: WI_Madison_West_20130722_TM_geo.pdf
Size is 13656, 17407
Coordinate System is:
PROJCS["UTM Zone 16, Northern Hemisphere",
Corner Coordinates:
Upper Left ( 294830.111, 4779306.587) ( 89d31'22.05"W, 43d 8'19.31"N)
Lower Left ( 294317.106, 4761635.933) ( 89d31'21.23"W, 42d58'46.52"N)
Upper Right ( 308692.951, 4778904.128) ( 89d21' 8.42"W, 43d 8'19.34"N)
Lower Right ( 308179.946, 4761233.474) ( 89d21' 9.19"W, 42d58'46.51"N)
Center ( 301505.029, 4770270.031) ( 89d26'15.22"W, 43d 3'33.04"N)
Band 1 Block=1024x1024 Type=Byte, ColorInterp=Red
Mask Flags: PER_DATASET ALPHA
Band 2 Block=1024x1024 Type=Byte, ColorInterp=Green
Band 3 Block=1024x1024 Type=Byte, ColorInterp=Blue
Band 4 Block=1024x1024 Type=Byte, ColorInterp=Alpha
So the file is fine but something appears to be wrong with the OSGeo4W
geopdf support. The binaries at http://www.gisinternals.com/sdk/ from
Tamas seem to properly support geopdf.
Best Regards, Eli
> Even though pdf is listed with gdalinfo –formats: PDF (rw): Geospatial PDF
> Anybody could point me to a solution to this? It’s much appreciated.
> (I saw a previous post about cleaning before a new installation. That could
> be my problem too. But not sure how to do this with windows. Any clue would
> be helpful, thanks!)
> Regards,
> Jian
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
